The proud Apple finally enters the 7-inch tablet scope. Although being doubted of its value of existence by many people, no one can deny the fact that iPad Mini is there. 7.9 inch also attracts critics’ questionings that if it is proper to define this close-to-8-inch tablet as a 7 inch product. Plus without the shinning Retina Display, folks can’t help asking, is this screen considered inferior? Apple’s answer to this would be ambiguous, because they do not want to say that its new iPad model is labeled with a second class tag.
To test its screen clarity, you can convert your DVD titles into iPad Mini compatible MP4 video to see whether or not it stands consumers’ doubts. You can use a DVD Ripper Software, like DVDFab DVD Ripper to do that.
Let’s see how:
Convert DVD Title for iPad Mini: Step 1-> Download and install the latest DVDFab 9 onto your computer;
Convert DVD Title for iPad Mini: Step 2-> Launch DVDFab 9, choose Ripper option at the Option Interface (or from the Option Bar at the Main Interface), then load the DVD you are about to convert;
Convert DVD Title for iPad Mini: Step 3-> Select the movie title, audio track and subtitle stream you want to keep at the Operation Window, click the Profile Box (or Profile Icon) to find iPad Mini from Profile Library and press "OK" button, then just hit  “Start” button at the Main Interface to go converting.
Product you need order: DVD Ripper
For more information, you can go to www.dvdfab.cn/dvd-ripper.htm.
